SDR server in router with Openwrt
Благодарил: 37 пъти
Получил благодарност: : 63 пъти
Мнениеот marsel90 » нед апр 16, 2017 7:10 pm
How install and open one SDR server in router with Openwrt firmware.
1. Install in router Openwrt firmware https://openwrt.org/
2. Install software rtl-sdr in router
3. Open with command "rtl_tcp -a your public ip -n 128 -b 16"
For connect i use sdr sharp
For a good inetrnet connection i use in sdr sharp 'sample rate 1024MSPS'
For a slow internet connection i use in sdr sharp 'sample rate 0.25MSPS'
For the moment i use one open dipol fm band.
Is open 24/7 please testing, sdrtest.ddns.net port 5900
In this moment work only for one user connection, if is busy, please try later.
Благодарил: 37 пъти
Re: SDR server in router with Openwrt
Мнениеот marsel90 » пон апр 17, 2017 6:55 am
Today i testing reception from my sdr server with 4g mobil connection.
For a perfect work i use this configuration in SDRTouch
Последна промяна от marsel90 на ср апр 19, 2017 8:59 am, променено общо 2 пъти.
Благодарил: 37 пъти
Мнениеот marsel90 » вт апр 18, 2017 12:10 pm
Good !
Next place Bucuresti, Timisoara,Constanta, Turnu Magurele and Drobeta Turnu Severin.
Благодарил: 37 пъти
Мнениеот marsel90 » вт апр 18, 2017 5:12 pm
SDR server in Bucuresti and this scan is in Craiova via internet.
Antenna - one vertical dipol indoor.
Here is Timisoara, a short pass band
In Timisoara not have antenna jet.
Благодарил: 37 пъти
Мнениеот marsel90 » ср апр 19, 2017 8:12 am
Today i testing my sdr server for reception with mobil phone
Благодарил: 47 пъти
Получил благодарност: : 57 пъти
Мнениеот RADIOTO » ср апр 19, 2017 11:37 am
marsel90,
Today i see something curious.
I can heard Digi FM on 105.5 MHz.
This is 106.5 MHz (with audio), but Digi FM transmitted on 105.5 MHz :
And on 106 MHz only RDS-PI without audio:
Благодарил: 37 пъти
Мнениеот marsel90 » ср апр 19, 2017 1:03 pm
Yes, today i put fm antenna horizontal 9 elements direction Tupiznica, and this sdr stick have a more intermodulations.
One problem is SDRTouch because not uses correct gain for sdr stick.
With pc and SDRSharp work perfect, i see 92.5 mhz, 100.4 mhz perfect and more that i see in SDR Touch.
Благодарил: 37 пъти
Мнениеот marsel90 » чет апр 20, 2017 9:48 am
A few reception from sdr server Bucuresti.
Receptions in Craiova via internet connection.
