Средни вълни на Балканите
Приеми в обхвата на средните (522 - 1620 kHz) и дългите вълни (153 - 281 kHz).
Has thanked: 41 times
Мнение от Georgi Bancov » чет юни 30, 2016 8:48 pm
Споделям списък със средновълновите емисии страните от Балканския п-ов, които се приемат в гр.Троян в една или друга част от денонощието:
531 kHz - ROU - Radio Antena Satelor - Urziceni (14 kW)
531 kHz - ROU - Radio Romania Actualitati - Petrosani (14 kW)
540 kHz - HNG - Kosuth Radio - Solt (1000 kW)
558 kHz - ROU - Radio Romania Actualitati - Targu Jiu (400 kW)
567 kHz - ROU - Radio Romania Actualitati - Brasov (50 kW) и Satu Mare (50 kW)
576 kHz - BUL - BNR Horizont / Bulgaristan Radyosu - Vidin/Gramada (200 kW)
603 kHz - ROU - Radio Oltenia Craiova - Drobeta Turnu Severin (22 kW)
603 kHz - ROU - Radio Romania Actualitati - Oradea (14 kW) и Botosani (50 kW)
621 kHz - MDA - Radio Pridnestrovye - Grigoriopol/Maiac (160 kW)
630 kHz - ROU - Radio Timisoara - Timisoara/Ortisoara (400 kW)
630 kHz - ROU - Radio Antena Satelor - Voinesti (50 kW)
648 kHz - SVN - Radio Murski Val - Murska Sobota (10 kW)
675 kHz - SRB - Radio Beograd - Bosilegrad (1 kW)
684 kHz - SRB - Radio Beograd - Aleksinac (30 kW)
693 kHz - SRB - Radio Beograd - Negotin (0.5 kW)
711 kHz - SRB - Radio Beograd - Nis (7 kW)
711 kHz - ROU - Radio Romania Actualitati - Sighetu Marmaţiei/Vadu Izei (50 kW)
720 kHz - ROU - Radio Romania Actualitati - Sinaia (14 kW) и Nufaru (14 kW)
729 kHz - GRC - ERA Proto Programa - Athinai (150 kW)
756 kHz - ROU - Radio Romania Actualitati - Lugoj (400 kW)
810 kHz - MKD - Radio Skopje - Ovce Pole (400 kW)
855 kHz - ROU - Radio Romania Actualitati - Bucuresti (250 kW)
873 kHz - MDA - Radio Moldova Actualitati - Chisinau (50 kW)
882 kHz - MNE - Radio Crne Gore - Gornja Plavnica (5 kW)
909 kHz - ROU - Radio Cluj / Kolozsvári Rádió / Radio Romania Actualitati - Cluj-Napoca (400 kW)
909 kHz - ROU - Radio Romania Actualiati - Timisoara/Ortisoara (50 kW)
909 kHz - ROU - Radio Constanta - Constanta (14 kW)
945 kHz - ROU - Radio Romania Actualitati - Miercurea Ciuc (14 kW)
999 kHz - MDA - Trans World Radio Ukraine - Grigoriopol/Maiac (500 kW)
1053 kHz - ROU - Radio Iasi - Iasi/Letcani (400 kW)
1107 kHz - SRB - Radio Beograd - Novi Sad (95 kW)
1152 kHz - ROU - Radio Romania Actualitati - Cluj-Napoca (400 kW)
1179 kHz - ROU - Radio Romania Actualitati Bacău/Galbeni (200 kW)
1179 kHz - ROU - Radio Romania Actualitati - Resita (7 kW)
1197 kHz - ROU - Radio Targu Mures - Brasov/Bod (14 kW)
1269 kHz - SRB - Radio Novi Sad - Srbobran (10 kW)
1278 kHz - GRC - ERA Florina - Florina (10 kW)
1296 kHz - SRB - Radio Beograd 1 - Vranje (8 kW)
1314 kHz - ROU - Radio Oltenia Craiova - Craiova (14 kW)
1314 kHz - GRC - ERA Proto Programa - Tripolis (10 kW)
1323 kHz - ROU - Radio Targu Mures - Targu Mures/Ernei (7 kW)
1332 kHz - ROU - Radio Romania Actualitati - Galati (50 kW)
1395 kHz - ALB - Trans World Radio Europe - Fllake (500 kW)
1404 kHz - GRC - ERA Komotinis - Komotini (50 kW)
1404 kHz - ROU - Radio Cluj - Sighetu Marmaţiei (50 kW)
1404 kHz - ROU - Radio Romania Actualitati - Sibiu (7 kW)
1413 kHz - MDA - Radio Vesti FM - Grigoriopol/Maiac (500 kW)
1422 kHz - ROU - Radio Romania Actualitati - Ramnicu Valcea (7 kW)
1458 kHz - ROU - Radio Romania Actualitati - Constanta (50 kW)
1458 kHz - ALB - Radio Tirana - Fllake (500 kW)
1485 kHz - GRC - ERA Volos - Volos (1 kW)
1494 kHz - MDA - Radio Moldova Actualitati - Cahul (30 kW) и Edinet (20 kW)
1503 kHz - SRB - Radio Beograd 202 - Beograd/Mecevici (10 kW)
1530 kHz - ROU - Radio Romania Actualitati - Nufaru/Releul Delta (14 kW)
1530 kHz - ROU - Radio Constanta - Radauti (14 kW)
1548 kHz - MDA - Trans World Radio Europe - Grigoriopol/Maiac (500 kW)
1584 kHz - ROU - Radio Vocea Sperantei - many 1kW txs
1593 kHz - ROU - Radio Targu Mures - Miercurea Ciuc (1 kW)
1593 kHz - ROU - Radio Cluj - Sibiu (7 kW) и Oradea (7 kW)
Както виждате, списъкът е съставен главно от румънски станции, част от които се приемат целодневно със силен и чист сигнал. Вечерно време и през нощта обаче слабите предаватели също изплуват и обикновено се чуват добре и борят по-силните такива. По-голямата част от сръбските станции (с изключение на 684, 1107, 1269 и 1503 kHz) са маломощни и се чуват само нощем или рано сутрин, когато отсъстват други сигнали на техните честоти. Транссветовното радио със своите религиозни програмим от Албания (1395 kHz) и Приднестровието (1548 kHz) се чува все така силно. Гърция силно редуцира своите емисии на средни вълни в последните няколко години, особено при сътресенията около закриването на националните радио и телевизия, но момента излъчва с няколко предавателя на средни вълни. 729 kHz се чува прекрасно вечер, като 150-киловатовият сигнал стига дори Западна Европа (Великобритания, Франция и Холандия) и на моменти успешно се бори с испанските сигнали на същата честота. Видинският предавател излъчва с намалена мощност (200 kW) и се оказа абсолютен провал със ниската си модулация и отвратителното покритие.
Емисии на български език на средни вълни освен от БНР, могат да бъдат чути както от Транссветовното радио (всяка вечер от 21:00ч на 1548 kHz), така и от Радио Тимишоара (всяка неделя от 19:00ч на 630 kHz) и Радио Молдова Актуалитати (чувал съм ги на 873 и 1494 kHz, но точното им разписание не ми е известно).
DX-er
Регистриран на: ср юли 06, 2016 5:37 pm
Re: Средни вълни на Балканите
Мнение от DX-er » ср юли 06, 2016 6:12 pm
Пишам чрез Google Translatte
В Македония има само един активен предавател на средни вълни, той се намира на Овче поле и частотата му е 810 KHz и предава програмата на радио Скопие / Македония. Мощността му е 1200kW + антена, или общо 1500kW EIPR.
В момента работи с много ниска мощност, предполагам, че е около 200-300kW и около 800kW в момент, когато се излъчват програмите за чужбина
Мнение от Georgi Bancov » пет яну 06, 2017 1:27 pm
Средновълновият предавател на ERT в Мегара ще заработи отново: http://www.thegreekradio.com/node/28583
Been thanked: 354 times
Мнение от Георги » нед фев 19, 2017 7:45 am
DX-er написа:В Македония има само един активен предавател на средни вълни, той се намира на Овче поле и частотата му е 810 KHz и предава програмата на радио Скопие / Македония. Мощността му е 1200kW + антена, или общо 1500kW EIPR.
Според мен е с не повече от 100-200 kW денонощно, иначе не биха се приемали две станции върху неговия сигнал в недалечния Солун:
https://www.youtube.com/watch?v=1FMWMAhuIEg
Tonimak
Регистриран на: съб авг 20, 2016 6:00 pm
Has thanked: 3 times
Been thanked: 34 times
Мнение от Tonimak » съб мар 18, 2017 9:20 am
от телефонен разговор с надлежните получих информация че в момента предавателя на Радио Скопие -Овче Поле излъчва само с 100 вати и денем и нощем Денем с средно качество на североисток от Овче Поле го слушам в Град Лом
IvanFL
Регистриран на: пон ное 14, 2016 11:30 am
Been thanked: 46 times
Мнение от IvanFL » съб мар 18, 2017 3:47 pm
интересно каква е съдбата на огромния брой малки "селски" предаватели на средни вълни в старата югославия? През 90-те години и по рано те бяха много и пръснати навсякъде.
Мнение от Георги » съб мар 18, 2017 3:50 pm
От години са предадени за скрап и преработени.
나의 LG-K520 의 Tapatalk에서 보냄
